What Carpet Glue do you box builders use?
I'm old school and I use contact cement! Mainly it is because I worked as a carpenter's helper one summer while in high school and I've always had better luck with it over the spray on glue.
tbh, the stuff walmart sells works pretty well and it's cheap enough to use a shit load to make sure it works. you can probably get 2-3 cans of it for the price of one 3M super 77.
it's called Dura-someshit.. forgot.
I hate that shit, by the time you apply enough for it to work you have used as much as you have saved by buying the cheaper stuff. Around ports and such it loves to peel off.
I like super 77 but like other have said its expensive, so I use a weldwood water based contact cement shot out of an hplv gun. There is more setting time but that carpet will NEVER come off. And i buy it by the gallon for $20
And Mcsoul and I used the elmers, its terrible
I spray both contacting surfaces. works for me. the carpet in my beauty panels in my trunk is holding up just fine over a year now. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif werks 4 me like hooked on phonics.
i work on pools for a living and we put oam on the inside of are pools under the liner...we use 3m super 77 we have done liner changes in 15 plus year old pools that had there foam put on with 3m and it hold up to mosure and all kinda of abuse...it almost impossible to get off something that has been sprayed with that...i covered my work bench with some old rug and 3m and it holds up like it was welded..//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif idk if that helps but i will use 3m on everything
To think about it more Im talking about Duro spray adhesive from home depot..same stuff?
I might not have used enough
steveBeatz
Banned
steveBeatz
Rancho Cucamonga, CA
jack0409
