What can you tell me about wire size
I keep forgetting this is a 5 ch. 4 ch at the 2.3 ohm load is fine, and if that sub box final load is at 2 ohm then you are fine.Just got to lower gains down and not crank everything up on the HU, Like LOUD(I never use) (BASS BOOST) I never use. 120HTZ or Through for basic setting i use on Mids and highs and approx 1/2 gain or turn up to where Ill be playing majority till I hear speakers disrtort and turn gain down a 1/4 till no longer noticable, been working for me just fine for over 20 years.That Amp will shut down if it gets too hot(Supposed to go into protect)Safe mode.
But if you want it to run cooler(Amp) I suggest you get an amplifier for sub duty alone and run that 5 ch. on your mids and highs since you have it utilize it. All 5 and 6 and 3, and even quite a few 4 ch bridged at a lower ohm load run warm to hot when used as a multi amp application for sub duty along with front stage/and rear stage at the lower ohm load. Being driven hard..
xromarx
xromarx
Albuquerque
audiobaun
