what can these do me ?
1. whats the punch45 capable of ??
2. can this amp push rockford t162s comp speaker with 100 rms?
1. About 2 x 70-80w RMS at 4 Ohms, 14.4V, 1% THD (they are very underrated amps).
2. Yes, it'll work fine with those comps. Might be a bit starved for power, as even the RF 100W RMS rating is a little conservative from what I've read.
jman's recommendation of the MBQ PCE's is a good one.
Others to check out:
Polk Momo MMC6500
Apline Type X
Pioneer REV
Kicker RS652
Rainbow SLC265
Crystal SSCS6
Diamond D661S
Pioneer 720PRS
Eclipse SC8264
Go out and have a listen if you can!
Subs:
Use the JBL subs you have. Might as well make use of what's already available.
Since both subs are Dual 4 Ohms VC models, you'll have to wire them together for 4 Ohms total impedance on the amp. They'll only be getting about 120-150W RMS each, but it's a start. Or you could just run 1 sub at 2 Ohms (600W RMS from the amp, about double the OEM rating for the sub) and be very conservative with the gain setting.
Unless you want to get different subs.
jojo1212
jojo1212
ummm
ultimate157
