what box to build for kicker comp 12
dman1049
I'm going to build my own box, I listen to rock and rap. I want a box that will sound good in those 2 situations. I dont care what kind of box sealed, ported or bandpass i just want to know which box will work the best for me. subwoofer specs see below.
fs-26.5,
peek of 300 watts and 150 rms,
SPLo-89.1
effective excursion-.38 inch or 9.76mm
Re-3.69
Qms-9.61
Qes-.447
Qts-4.27
Vas ft cubed-4.5
Net displacement inches cubed- 105
how do i tune a port? yes im a noob. the manual says to go 2.25 ft^3. i really want a heavy bass hit so thats why i chose ported in the first place. will ported sound ok with both rock and rap?
kicker shows in the manual how to make a ported box. in my case i didnt use there design but the idea is lengthen the port for deeper response but as you tune deeper you stifle the higher bass. that sub sucks and doesnt play very low at all i would tune it to around 40hz.
if you use a round port this is the length you need for a 2.25 cu ft box
4" port - 6.5 inches length will get you 40hz
9.5 inches length will get you at 35hz.
I would stay in between that area for that sub and remember to use your amps subsonic filter if it has one
because high power at frequencies below the tuning of the box can kill your woofer over time or insttantly depending on how high the volume knob is.
It all depends on how much port area you want. I can help you out with all this dman. Shoot me a PM and I can draw something up for you.
I was going to just design it for him for free //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
dude said free. that was total bullshit. i pmed him and he said he'd do the design for $8. i deleted the pm and never got back to him. i was going to do it myself anyway. really just wanted some tips.
dude said free. that was total ********. i pmed him and he said he'd do the design for $8. i deleted the pm and never got back to him. i was going to do it myself anyway. really just wanted some tips
Ive ran ported and sealed id go ported. Just try and get the specs for the exact sub u have and that will get u started, then figure out the amt. of space u have to werk with. Be sure and measure from the inside of yer box. Dividing yer inch measurements of yer cubed box plan bby 1728 will give you the footage cubed that yer lookin for. Ports i know little about, i know u can jigsaw a 4" hole on the front of yer box and get 6 feet of 4inch pvc pipe and make yerself 10 port tubes of varying length then u can change them out and decide on that.
dman1049
dman1049
silverdale. wa
CertifiedHoodClassic
