B Bass911 10+ year member CarAudio.com Elite 1,199 33 Dallas,TX Apr 2, 2012 #1 What is the best glue to use for bonding concrete form tube to MDF? I'll be using it for a port. I'm a assuming it's Liquid Nails? Click to read more...
sacsking916 5,000+ posts stayin high an loud 6,714 187 emerald triangle..home of da trees Apr 2, 2012 #2 Screws an silicone or liquid nails.
hispls 5,000+ posts CarAudio.com Veteran 13,451 1,865 Central Maine Apr 2, 2012 #3 Liquid Nails, Amazing Goop or CA glue...though CA glue can be a bit messy if it isn't snug in the hole and you use thick glue and activator. Staple gun goes a long way to secure it in place as well.
VisceralSound 10+ year member CarAudio.com Elite 1,657 2 Rochester, MN Apr 2, 2012 #4 I just used Titebond wood glue then used caulk around the seams to seal it
OP B Bass911 10+ year member CarAudio.com Elite 1,199 33 Dallas,TX Apr 2, 2012 Thread Starter #5 Ok, thanks. I think I'll be going with Liquid Nails. Does it need bracing at back or near the end of the port? The port will be 16-17 long.
VisceralSound 10+ year member CarAudio.com Elite 1,657 2 Rochester, MN Apr 2, 2012 #6 Mines 25.25" long and I have a sheet of MDF cut just big enough to fit the sonotubes for support.
