What are these specs rated at?
ArrizX
Scout 800 owner.
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5223
I plan on buying that amp Powerbass ASA-600.4
But it says this
* 4 ohm Power : 100W x 4
* 2 ohm Power : 200W x 4
* 4 ohm Mono Power : 400W x 2
* Peak Power : 1600W
* Total Harmonic Distortion :
* Frequency Response : 20Hz - 22,000Hz
* S/N Ratio : >94 dB/W/M
* Damping Factor : >150
* Input Sensitivity : 0.5 - 4.0 volts
* Crossover Slope : 12 dB
* High-Pass Crossover Freq : 40Hz - 250Hz
* Low-Pass Crossover Freq : 40Hz - 250Hz
* Variable Subwoofer EQ : 0/+18 dB
* Subwoofer EQ Frequency : 40Hz
* Dimensions : 14.9" x 9.3" x 1.9"
* Dimensions : 380mm x 238mm x 48mm
ASA600.4 - Powerbass 4 Ch 1200 Watt Power Amplifier ASA 600.4
So, my speakers will be at 4 ohms. Will I really see that many watts? Or is taht rated for like 14.4volts. See, my jeep charges at 14.4 volts but battery sits at like 12.7 or whatever is standard. So I'm not sure what voltage my amp will see. Maybe the voltage the amp will see is 14.4 because ill be using this when its running.
Helpp...
ArrizX
Scout 800 owner.
ArrizX
Somewhere drinking moutain dew...
ArrizX
