just use 1 1/4" dowls. they work just fine.Any Pics Of The The Thread Rods And How Or What To Use To Keep Them In The Box Lol Ima Be Running 2000+ Watts Maybe Reach To 4000+ If I Get Me The Atomic 5000.1 Amp.I Might Go With 2 15s Btl Not Sure Yet Any Wayssss........
1) Cut the rod to where it's a few inches longer that the entire external dimension of where you're wanting to brace.Any Pics Of The The Thread Rods And How Or What To Use To Keep Them In The Box Lol Ima Be Running 2000+ Watts Maybe Reach To 4000+ If I Get Me The Atomic 5000.1 Amp.I Might Go With 2 15s Btl Not Sure Yet Any Wayssss........
Yes, but consider this is being done after the fact, so that's really next to impossible to implement now.the rods will only brace the enclosure right at the point of penetratin though the enclosure....out to a radius around the rod depending on how thick the material is....it does work well...but not entirely as well as a baffle/lattice type bracing panel would
Where the H does it say that the box is already done?Yes, but consider this is being done after the fact, so that's really next to impossible to implement now.
I agree. Dowels will have a considerable resonant quality you may want to consider...depending on how long they are.1) Cut the rod to where it's a few inches longer that the entire external dimension of where you're wanting to brace.2) Drill two holes for the rod to go through.
3) Put a washer and nut on the inside threads of the rod inside of the box. Tighten them enough so where the rod is tight in the box. Don't over tighten.
4) Put a washer and nut on the outside of the box where the remaining thread is and tighten.
This method is much better than dowels, imo.
