what amp would you use
4runnercrazy
Mattchu
well ikesound doesn't have n e more viper 1200.1's left //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif so i need to find a new amp im going to push it at either a 2 or 4 ohm load (most likely 4 ohms) and my price range is about 100-200 bucks, n e seggestions
o and im looking for about 300-400 RMS (or more if nessessary)
and 1 more question is it n e different to wire something down to 2 ohms instead of 4 ohms (other than the power difference)
I have a planet audio PA-2250D that will do its rated power of 2250w @ 1 ohm, 1200w @ 4 I believe. It might be more power than you need right now, but you always have room to upgrade later; and for $215 shipped you cant beat it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
And the only difference between the two wiring options is that 2 is a lower impedance (less resistance in the circuit), no audible difference if its the same power output.
What is the voice coil configuration and the rated power for your sub(s)?
i havent bought them yet, but im going to buy a brand spanking new type r
http://cgi.ebay.com/ALPINE-SWR-1242D-12-SUB-TYPE-R-SUBWOOFER-BRAND-NEW-06_W0QQitemZ5857616320QQcategoryZ18803QQrdZ1QQcmdZViewItem
Impedance 4 Ohms
Dual Voice Coil
Power Handling: 500 watts RMS, 1500 watts peak each subwoofer
Frequency Response: 24Hz – 500Hz
Kevlar Reinforced Pulp Cone
Custom Cast Aluminum Frame with Integrated Perimeter Venting and Heat Transfer Plate
Mirrored Progressive Nomex ® Spiders with Reinforced Layer Integrated Tinsel Leads
Compound Radius Curve (CRC) Motor Structure
Multi-Stage Thermal Management System
HAMR Surround and Concealed Mount Gasket
Aluminum Airflow Motor Cover
4runnercrazy
Mattchu
4runnercrazy
Danville,CA
4runnercrazy
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
