KorpzJuggalo
The Neck Cutter
I will be powering a kicker solox18" at 1ohm(hopefully, unless I get talked to doing 2ohm's). I would like to run a 7kw amp to this, but I'm not sure if it can actually handle it. Does anyone know by experience or reviews if it would be a good idea to power this with 7kw. If it can handle this much power then I was thinking of these- Cactus 7kw, Sampson( I know this is 8k, but it is in the 7k range), Stetsom, or Atomic. If 7kw is overpowering then I was going to choose a 5kw amp. For 5k I am stuck between Goliath, 5kw Cactus, 5kw Atomic, or 2 2500.1 Kickers. I have heard mixed reviews about all of these amps. I would like to run 7kw to the sub, but not if it is overpowering. I would just like to hear other people's opinions on these amps and hopefully I can finally make a decision. I am looking for the overall best amp. The goal is to hopefully get into some local comp's, so I would like an amp that would be best for this use.
Off-topic question so I don't waste another thread-
Will 3 Kinetik 2400's along with 350HO alt do the trick for 7kw or will I need another batt? (In your opinion!)
Thanks peace-
Thanks peace-
