what amp would fit these subs?
Airman21
i am going to buy 2 15" Mags i was wondering what amps people run with these or what you suggest i should run... $800 is my limit for subs amp i think but i could maybe spend a little more depending on the product... thanks
i heard the 20.1 would work good with these wired down to .5 but i dont know if that is good for a daily setup?
i was looking and found these two... how would they work with these subs and are they good amps?
2-US Amps XT-2000D..1200x1@1ohm
2-Crossfire VR 1000D
Doesn't the Sundown 1500D put out around 2300 watts at .5 ohm? That should be plenty I would think, don't need to buy two when you can use one. Just throwing that out there.
awesome i will go with this amp then.. thanks... This is a good solid amp correct? no problems running it daily .5? thanks again
never mind i see what your talking about ( soundstream amp)... can i use that one amp and push both subs.. how many watts would each speaker get? are those soundstream amps any good? i dont know much about the wireing the sub down to .5 or 2 or anything like that i am pretty new to this.. thanks
Airman21
Airman21
Ohio
Airman21
