What amp to get with specific speakers.
  • 2
Qsta
Hi audiophiles,
I am fairly new to audio installation on amps, luckily I have some friends that kind of know how to install amps and such however I need help in determining what amp I should get for my polk audio speakers, both the front (component) and rears (coaxial) are each 100 RMS @ 4 Ohms so would I need a  4-channel Amplifier that is 400 watt max or can I just go higher and control the Highs to not risk blowing my new speakers?
Really I just want to know what Amps would you guys recommend based off of my speaker requirements.
These new Pioneer GM series lineup has pretty good power and surpass the power rating, check it out
https://www.sonicelectronix.com/item_63974_Pioneer-GM-D8604.html
Too much power is not a thing in my book, as long as you gain the amp to proper level with good tuning if you're running active crossover.
In my experience, when i'm using a overkill amp, not only it outputs always clean power but also better low noise performance. It's kinda scary tho setting my gain super low 😂
The second HU was used to show the two RCA connectors from the HU to the amp. The first HU where it is labeled <subwoofer preout> is only showing...
22
72
Thanks for all the advice. Ultimately, I was able to get them to honor the warranty contract. It took a lot of back and forth and I received...
230
Never said they were. Commentary was more to being able to purchase one or the other or 40% off and take a 90 day warranty... which I would in a...
277
Lowering the impedance will also lower the speakers motor control, or damping, in physics no free lunch exists. It’s all give and take.
213
Qsta
Qsta
Qsta
    Apr 28, 2024
    Apr 28, 2024
