What Amp should I get?
I have two DVC Alpine Type-S 2ohm 10 inch subs that are rated at 600w RMS each. Just wondering what amp you’d recommend for me to get on a budget. I’d like to spend around $200 but will go higher if needed. Thanks
You should buy a Skar 1200 watt monoblock class D for your Alpine subs. Alpine Type R subs would be my choice..Purchased from Amazon is under $125. I'm sure you'll like Skar amplifiers and buy another from them again. Be sure to wire both subs correctly at 2 ohms or even 1 ohm to experience unbelievable lows.
Currently I'm running a Skar 12" dual 2 ohm voice coil sub with a 4500 watt monoblock amp. I connected it at 1 ohm with 0 gauge copper wire. My amp at 1 ohm will produce true 7000 watts and make a fire inside the car if I go full power. I will get pulled over and a ticket if I'm bumping it!
Your skar amp will catch on fire if you go full power?
Trudeau44
Trudeau44
New York
deez283
vegang
vegang
