What amp should i get?
strypersux
I Love McDonalds
I have two 12 inch kicker L5 DVC 2 ohm, im wiring it down to one ohm, and i have a few choices for amps which one of these is the best?or are there better options
looking to spend about 400
kicker sx 1250.1
rockford fosgate t1000bd
sundown 1200d
audioque 1200d
mtx jackhammer 1200d
if you have 2 ohm DVC than you cant wire down to 1 ohm, you can put each speaker itself down to 1 ohm but not as a pair. The amp will see a .5 ohm, or 2 ohm load. So you will need an amp that does that power at 2 ohms
if he uses the sundown for sure (dont know about the others haven't used or seen them) he can wire each sub to one ohm use a dual chamber box and hook up each sub to a channel as there are 4 outputs on the sundown
strypersux
I Love McDonalds
strypersux
Tri Cities, Michigan
G0NGSHOW
vegang
vegang
