What AMP? need advice PLEASE
FREEZE
I NEED to know what the best amp would be in my situation. I am getting 2 10 Inch alpine type R's. 300w RMS each. some stuff below for your review. Please let me know what you think is the most logical amp to buy please!!
Features
Frequency Response: 28Hz - 2kHz
Bass Engine Ready
Kevlar Reinforced Pulp Cone
High Excursion 1" Santoprene® Surround
Dual Custom Progressive Nomex® Spiders
Custom Cast Aluminum Frame
Extra Length Extended Pole
Flared Pole Vent
Bumped Backplate
Heat Transfer Plate
High Strength Brass Voice Coil Bobbin
Double Stacked Magnets
Strain Relief Terminals
Heavy Duty 8ga. Push Terminals
Oversized Parabolic Dustcap
My price range is open. I was thinking of getting an Alpine or JBL amp. I dont know how much power the amp should put out or anything, thats why i need your help. I would like to spend less than $225, but will go higher if need be.
since your subs are 300 wrms a piece you should get a 600 wrms amp. since you said you were considering alpine or jbl, look into the jbl 600.1
Since you're getting two dual 4 ohm drivers, you should look for an amplifier that produces 600-1000 RMS @ 1 ohm or 4 ohms ...
Those MTX amplifier produce their optimum power @ 2 ohms, so they're out of the question ...
Thanks JMac, do you have any suggestions on a good buy?
FREEZE
FREEZE
PHILLY BURBS
FREEZE
AJ (ACE)
    Jun 28, 2026
