What amp for two MTX 8500's
Im purchasing a new system and im going to go with (2) MTX 12 inch 8500's and im going to slap them in a ported box. I want to stay in the 2 ohm range for the final load on an amplifier but I have a few amps in mind that run down to 1 ohm. Amps I have in mind are:
Hifonics Brutus BX1000D
(2) Hifonics Brutus BX500D
Viper Audio 1200.1
(2) MTX 421D's (But has no subsonic filter)
Anyone have any opinions or maybe some other amplifier options? //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Buy a mtx 81000d monoblock amplifier it will make your 8500's pound.. I just sold a pair of 12's and I still have my mtx 9500 15 inch subwoofer hooked up. It's a great amplifier...
In Pop's absence I will post it for him.
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
190
389
487
  • Locked
777
Trancer
Trancer
Allen, Texas
Bobbytwonames
