JHardee
Cadillac
im looking for what amp i should run on my AQ Hdc315 (d2). any suggestions?
LMFAOATRMF'r //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gifyeah if the AQ2200 is in your budget then it would be a good choice. the Hdc315 should be able to handle a little more than 1000wrms, but probly not quite 1300wrms, so keep your gains on the lower side. Another advantage to the AQ2200 over the AQ1200 is Headroom. it will allow you to upgrade your subwoofer situation later on down the road.
i see most people running 1500+ to there HDC3syeah if the AQ2200 is in your budget then it would be a good choice. the Hdc315 should be able to handle a little more than 1000wrms, but probly not quite 1300wrms, so keep your gains on the lower side. Another advantage to the AQ2200 over the AQ1200 is Headroom. it will allow you to upgrade your subwoofer situation later on down the road.
^^^^ what he said //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gifLMFAOATRMF'r //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
