S Sidefx 10+ year member Member 44 0 Dayton, OH Sep 2, 2002 #1 i dont want something too much, its a single jl im running its the dual 2 ohm version. what amp should i get and how do i wire a dual speaker? Click to read more...
bass_mekanik 10+ year member i got 0.5 2 go til 145dbs 927 0 Launceston Tasmania Sep 3, 2002 #2 a jl 250/1 amp will boot it good and hard here it is http://www.jlaudio.com/amps/2501.html
OP S Sidefx 10+ year member Member 44 0 Dayton, OH Sep 3, 2002 Thread Starter #3 is there anything cheaper?? also i was thinking about buying from ikesound.
A ace7733 10+ year member CarAudio.com Elite 3,947 0 USA Sep 3, 2002 #4 JBL 300.1, ikes has those for 145 shipped http://www.ikesound.com
OP S Sidefx 10+ year member Member 44 0 Dayton, OH Sep 3, 2002 Thread Starter #5 ill get the 300 how should i run the wires cross them or not??
A ace7733 10+ year member CarAudio.com Elite 3,947 0 USA Sep 3, 2002 #6 well with (1) 2ohm dvc you can wire it for 1ohm load or a 4ohm load
OP S Sidefx 10+ year member Member 44 0 Dayton, OH Sep 12, 2002 Thread Starter #7 what do u think of the rockford 200s?? so i should on the sub connect the + to the - and the +to the - on the other side?
B blackgeltabs 5,000+ posts Knowledge is Power 5,415 0 Boston Sep 12, 2002 #8 200s would work just fine. Wire the sub in series so it sees a 4ohm load then bridge them amp, this will get the most out of the amp/sub.
OP S Sidefx 10+ year member Member 44 0 Dayton, OH Sep 12, 2002 Thread Starter #9 or ill just get the 99 pioneer 200 watt amp, or should i get the lightning audio 200 watt amp? that way i can get the q logic box
OP S Sidefx 10+ year member Member 44 0 Dayton, OH Sep 12, 2002 Thread Starter #10 or ill just get the 99 pioneer 200 watt amp, or should i get the lightning audio 200 watt amp? that way i can get the q logic box
mykeys 10+ year member URABUS 1,061 0 South Prairie, Wa. Sep 12, 2002 #11 The JBL would work fine.. The sub is dual 4ohm VCs hence 2 ohm in parallel. If memory serves they are rated for 250 watts but will easily run 300+ without any issues. Mike
B beatha 10+ year member Junior Member 22 0 Australia(TAS) Sep 14, 2002 #12 I agree with bass mekanik
OP S Sidefx 10+ year member Member 44 0 Dayton, OH Sep 14, 2002 Thread Starter #13 well i ended up getting a alpine 200w mono amp
