What all goes into a single 15" xxx build?
right now the f150 is being sold and im buying a lincoln ls, now that i have a trunk and room to do a build i want to do it right. As far as a single 15" xxx goes, what would i have to do? Would i want a d2 or d4? would i wire it at 1 ohm? what would be the ideal amp? can i get the max out of this sub with the room i would have? 90% of the time i listen to rap, so should i go ported or sealed? can i get away with the big 3? or will i have to upgrade my alt? Lots of questions to be answered. I will have quite a a bit of money to drop on this once i get the car, hopefully. Any input would be appreciated, some of my questions may sound dumb, but im trying my best here.
which ever i can get my hands on, for a good deal. I guess that could make or break it huh? I prefer a 06 or up model if possible.
05 model power wise will do well with 1k-1800 watts or so, 06 and up model needs a minimum of 2500 watts to even get moving. The 06 model is a super inefficient woofer.
1k-2000 watts usually can be run with stock alt as long as u have the battery back up and don't beat on it too hard. 2500 watts and up will really start to make a stock alt sweat, especially on the LS. A buddy of mine had a bxi2006d @ 1ohm in his V8 LS w/ a kinetik 1400 under hood and 2400 in trunk, and still had sum decent voltage drops. Like low 12s to high 11s when he would play a real low song.
so you think i can get away with maybe a 1500 watt amp and an older xxx? without having to swap out my alt or anything?
It wouldnt' be out of the question but I wouldn't beat on it too hard for too long. People run HO alts and multiple batteries for 2 reasons:
1. Less voltage drop = Better performance
2 Less voltage drop = No magic smoke
Ryan1126
Banned
Ryan1126
San Diego
jpexpc
