wet sanding
what ive done is, stand, resin,matt,resin,matt again were needed,resin,resin, (sand between each coat), and now im gunna sand it with 220 grit to make it all smooth and flush, then primier then paint then clear coat then wet sand... correct?
k so far ive done the resin and matt coats and sanded between each coats.. now i use bondo to fill in holes.. let it dry... sand it again.. then add primer.. wet sand.. then color and clear coat and wet sand again...correct?
jay99
jay99
Canada, ONT
jay99
