vorgath
Well I've been talked out of putting sub(s) in the backseat, seems like a really bad idea, cancellation etc involved.
So I'm going for a ported enclosure in the trunk. Here's my plan and also what I got so far:
Bought a 10 inch woofer, an Infinity Reference 1042W dual voice coil.
Got sound deadening material so I'll line the the trunk and especially rear glove compartment and spare tire compartment with it.
As far as amp goes, seems people here recommend a Directed Audio 250D ? Seems like a good deal, 49 bucks plus shipping, my question is though, if I run it at 2 Ohm, would it be too powerful for the 1042 ? The woofer can handle 250 RMS, 1000 W max.
I got the manufacturer spec sheet in front of me, the vented box volume listed is 1.75 cubic feet, port diameter is 3 inches, port length is 9 inches at 28.0 Hz. Can I run two ports rather than one ?
Could someone please explain this to me, the frequency etc etc, tuning etc ? I'd like to start this project asap, i.e. go and buy the MDF etc and build the box (does Home Depot or Lowe's cut the MDF for you or are you pretty much on your own ?)
Also, I won't always be driving with everything closed, once it gets warmer I'll probably end up driving more with my t-tops off.
Trying to use WinISD, but entering the parameters for the driver doesn't reall ywork, since my specs don't list the following:
Z
SPL
PE
Z
SPL
PE
