inapontiac
since knu is pretty much sold out, welding supply is my next bet. would it be better to go with 1/0 or 2/0 from them?
Are they bigger including the outer protection or just the metal/ actual wire its self..The Knu Kolossus, Kicker Hyperflex and Lighting Audio are basically the same size as the 2/0ga welding wire (the 2/0ga welding wire is just slightly larger). The 1/0ga welding wire is quite a bit smaller than those three. I have all those different sizes and brands.
To answer your question, the welding wire is just fine if your okay w/ not having fancy translucent colors.
it's a lost cause. hyperflex means it's louder and cleanerbull shit mang.
2/0 welding cable is going to be the same thing as 2/0 "car audio" cable.
welding stuff is just not as pretty looking. fact is, usually "car audio" wire companies try to scimp out and cheat the buyers out of product by cutting corners and making thicker jackets. think scosche.
welding wire should work perfect. i have it. i have 1\0. and its thick and works perfect. just not a cool clear blue jacket. *shrug*
Isn't that the truth.it's a lost cause. hyperflex means it's louder and cleaner
When I say bigger or smaller; I am refering to the actual copper only, not the jacket.Are they bigger including the outer protection or just the metal/ actual wire its self..
