Welding Wire for Big 3??
The only reason I wouldn't use welding wire for the big 3 is because of the flexibility of it.
I'll be doing my big-3 in hyperflex soon enough.
:confused:It's flexible enough. I have both types of wires in my truck. While I prefer something along the lines as hyperflex, welding wire does the job.
I'm not sure if "welding wire" refers to a specific brand/source or not. I had 1/0 wire that was made for use in welding, had only ~150 strands, and was terrible to use in a car.
I'm not sure of the strand count or awg of the strands, but what I have is basically the same stuff that you would buy from weldingsupply.com It's not tinned like hyperflex, but does have a really soft black jacket.
for under the hood my only concern would be thermal resistance of the insulation.
If it's designed to be kicked around on a shop floor there might not have been a lot of attention given to heat resistance.
for under the hood my only concern would be thermal resistance of the insulation.If it's designed to be kicked around on a shop floor there might not have been a lot of attention given to heat resistance.
It has been under my hood for a long time w/o problems.
528hz
Everything'sMiscellaneous
528hz
In the Space between Space in NM
jco1385
Mike Mccabe
