Figured I'd just link you into the thread I poasted about it a while back. As long as you're sure you're not clipping and they are in no way HOT it should be alright... I can play mine for an hour straight at full tilt... which I do on a semi-regular basis and the caps never get more than slightly warm to the touch.Yes. just warm, not hot
Easy to say because it's probably true, but 1200W is a lot of heat any way you cut it and IMO warming up the coil is to be expected. As long as it isn't getting stinky I don't think it'll do any harm.clipping
Im running it at 3ohms, it should only be getting around 600 maybe 700 at mostEasy to say because it's probably true, but 1200W is a lot of heat any way you cut it and IMO warming up the coil is to be expected. As long as it isn't getting stinky I don't think it'll do any harm.
Whatever. Put your hand on a 100W lightbulb and let me know if 100W is a lot of heat. In any event warm is normal, smelly is bad.Im running it at 3ohms, it should only be getting around 600 maybe 700 at most
Just burned myself //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif thanks man....Whatever. Put your hand on a 100W lightbulb and let me know if 100W is a lot of heat. In any event warm is normal, smelly is bad.
That'll teach you that even 100W of power is a lot of heat! You have learned a valueable physics lesson that you won't soon forget.Just burned myself //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif thanks man....
Have before, not gonna do it again! No smell or anything! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifWhatever. Put your hand on a 100W lightbulb and let me know if 100W is a lot of heat. In any event warm is normal, smelly is bad.
