Want to tune a sub to 33hz
i'm asking cause my friend has a 12" sub with a 1200 watt amp i think in a 1.3 cubic feet ported box. it sounds rlly weird so we want to know why
knowing you, the amp isn't a true 1200 watts, the sub is probably pure garbage, and the box is tuned too high, and the gains are cranked all the way up.
how will pics tell you anything? that won't tell you what model sub and amp they are. it won't tell you how it's ran. so chromite, what kind of sub is it (model number will be best), is it a prefab box? 1200watts? is this the rms rating? if so how many ohms? how did you wire it?(ohms)
Watch........... Hey slappin , what kind of sub is this??
images
I bet he knows what kind it is and about how much power it can handle.
Lets see...............
ok , then if this is true , the box is too small for that sub. It's probablly bottoming out , and the amp needs to be tuned correctly because its putting out more than that sub is rated for (not a bad thing , just be careful with it). tune it and build a bigger box,.
Chromite
Chromite
Los Angeles, California, United States
Chromite
