Want to tune a sub to 33hz
I understand the box size and port size but how exactly do you TUNE a sub to 33hz. Filters on amps mainly go to 40hz from what I've seen.
What exactly are you referring to? The only two filters you need to worry about on your amps are the LPF(low pass filter) and subsonic filter...I'm confused as to why you're trying to set either one at 33hz.
you don't tune a sub, you tune a sub box. So you have a box built and tuned to 33hz. your crossover(or what you call a filter) is there to cut the frequencies above where you set if. So when you set your crossover to say 65hz it filters out any frequencies above 65hz so your subwoofer gets 65hz and down. Now i'm getting confused, what are you referring to?
Chromite
Chromite
Los Angeles, California, United States
Chromite
