There us a promo code for a little off too...
I looked for one, and found out that the one I found expired on 3/31/12, by the way do you think that the audiopipe will be louder than a F2600.d SSL? That is what I am running right now, but I very seriously doubt that it is the true amp rating.
•SSL Series Monoblock Class D Car Amplifier
•RMS Power Rating:
◦4 ohms: 750 watts x 1 chan.
◦2 ohms: 1200 watts x 1 chan.
•Max Power Rating:
◦2 ohms: 1800 watts x 1 chan.
◦1 ohm: 2600 watts x 1 chan.
•Max power output: 2600 watts
•MOSFET PWM (Pulse Width Modulated) power supply
•Wired remote bass level control included
•LED power and protection indicators
•Bass boost (0-18 dB bass boost at 50 Hz)
•Selectable phase shift (0-180 Degrees)
•Mono channel operation
•Soft turn-on circuit
•Low level RCA input
•Preamp RCA output
•3-Way system protection circuitry (thermal, overload, and speaker short protection)
•Datalink port for strapping two identical Force Class D amplifiers together
•Heavy duty black anodized heatsink
•Nickel-plated RCA level inputs
•Nickel-plated screw terminals
•Variable low-pass filter (50-150 Hz, 24 dB/octave)
•Subsonic filter (24 dB at 15-45 Hz)
•Input sensitivity: 100mV-2V or 2V-8V
•Frequency response: 50-150 Hz
•Damping factor: 125
•Dimensions: 11-1/8"L x 10"W x 2-7/16"H
•4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
