Voltmeter?
you realize it takes a 5V supply? try to find one that doesn't require you build a DC-DC supply. or build your own with a voltage regulator circuit.
also, you need to buy a shunt resistor that has a voltage drop the ammeter will accurately register. so a 50A shut resistor is about $10. then the meter monitors the voltage drop across the shunt (usually 75mV). and the shunt goes in-line with the ground wire. the current on the ground wire causes a voltage drop across teh resistor, the ammeter measures the voltage and calculates the current.
for car audio, a 100A ammeter with a 100A shunt makes more sense (and costs the same). look on eBay instead of Amazon for a larger selection.
Oh! I clicked the one beside it, it was the same price and looked the same ect. Good eye.
I plan to flush mount one, and would rather it be the small compact style like that so my mounting options would be muuuch wider. Any suggestions as far as where to look for something like that?
i've owned those type before. they aren't as small as you think once you get them mounted. they do work, but will fry the instant you wire them wrong.
it says it includes the shunt, but it's not pictured and the price is too low to include the shunt.
wait, do you want a voltmeter or an amp meter?
---------- Post added at 09:49 PM ---------- Previous post was at 09:48 PM ----------
3 1/2 12v Digital Blue LED 20V DC Volt panel meter New | eBay
---------- Post added at 09:50 PM ---------- Previous post was at 09:49 PM ----------
honestly, if you have both - you can know actual power draw of the system (just multiply) and if you know amp efficiency you can quickly determine power delivered to the subs/speakers.
fannin88
fannin88
ky
keep_hope_alive
