Volt meter
BaldJewels
29
Montana
Hey guys- I just got my sub stage installed again and was here to ask a quick question;
I'd like to think having the meter wired into the amp would prove best.. So I did, straight into positive and negative. Then wired into my cabin.
This leaves the issue of no automatic relay leaving it always on.
Fixes please?
Gracias as always!
Or buy a volt meter with a switched input....
Or add a switch.
okay- I'll go to home depot and buy a light switch and mount it to the door of my Lincoln LS for my $8 volt meter.
Thanks
Thanks
you can get something more low profile than a light switch lol
Thanks
These are the kinds of responses that keep people with knowledge from contributing and helping others. (Sarcasm is really hard to catch in text)
Buy a relay for $5 on ebay....
Then you won't have to worry about turning it on and off. I've got two external relays for my audio system to run volt meters and turn amps on that have isolated electrical systems, so I don't burn up remote wires when systems try to balance out
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
im not looking to seal off im trying to stay out of wall classes and plan on staying in trunk classes
15
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
BaldJewels
BaldJewels
Montana
mrtonytompson
    May 18, 2024
    May 18, 2024
