voicecoil wiring options
1 JL 12w6v2 D4
Diamond Audio 600.2 with the following ratings:
RMS Output Power
150W x 2 @ 4 Ohm Stereo
300W x 2 @ 2 Ohm Stereo
600W x 1 Bridged @ 4 Ohms
# Freq Response: 10Hz-50KHz
# Signal-to-Noise Ratio: 102dB
# THD: 0.03%
# Channel Separation: 80dB
# Length: 17"
# Width: 12"
# Height: 2.75"
Can I get 600 to the 12w6? I don't think so.
I went to the Rockford Wizard on the site for help..
well.. I have Three 4 ohm DVC subs. the wiring on the diagram doesn't help.. are they saying to hook one coil to itself? or to hook across from one Coil's + to the other coils -?
sorry if thats confusing, I'll take some pics.. but I did get a result of 2.6 ohms.
But I want to double check my wiring.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=3&woofer_imp=4
That link is very clear to me. Is there a certain part of it that you don't understand? Each woofer will show an 8ohm load and then with 3 x 8 ohm woofers wired in parallel, that is 8/3=2.66ohm.
Hello everyone. I have a couple of questions, and I was wondering if u guys can help me. I have these subs, 2:
http://www.amazon.com/Kicker-CompVR-07CVR124-subwoofer-4-ohm/dp/B000MSSOWQ/ref=pd_bbs_sr_1?ie=UTF8&s=electronics&qid=1232689236&sr=8-1
Kicker 12" 4ohm DVC. So I was wondering if I got 2 of these amps one for each sub ofc, I would get 400 RMs out of those subs theorically.
http://www.crutchfield.com/p_2068ZX4001/Kicker-08ZX400-1.html?tp=115
In the diagram I have 2 ohm, So I would get the actually 400 RMS that the amp has theorically. Would these amps would work just fine. I won't have problems with burn fuses or overheating the amp? ... Thx in advance all...peace..
hi got a lil question... i have one 12" audiobahn immortal qvc 2ohm wired to 2ohm
and a a rockford p3 12" dual 4ohm wired to 2ohm..
the amp is a audiobahn a2300hct 2 channel can i wire these subs to 1ohm or should i just buy another rf p3 .... the amp is stable to 1ohm.... any comments suggestions....thanx in advance...
hi got a lil question... i have one 12" audiobahn immortal qvc 2ohm wired to 2ohmand a a rockford p3 12" dual 4ohm wired to 2ohm..
don't mix subs
paikiah
Wangaholic
paikiah
Seoul, Korea
tomi
BP1Fanatic
BP1Fanatic
