Voice Coil Problems ?
theblazemaster
I bought 2 alpine sws 12d4's and each coil works fine but when i try to run it bridged it doesnt work for some reason ? I checked my tinsel leads and there fine its literally only when i try an run bridged that it dont work but ea work separately ? If you could help it would be greatly appreciated //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
how are you bridging them? and what amp?
Sounds like you might have your wires backwards on one of the coils? They will fight each other and the driver won't move.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
484
I looked at Crutchfield. Sure enough, dudes right up does say it. I even looked on YouTube. There's only 1 review on the m7 subs, but it's...
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
871
theblazemaster
theblazemaster
Spring hill
MutantDreams
    May 16, 2024
    May 16, 2024
