Voice Coil Help!!!!!
amp not that strong.
explain. The only reason I would think you would want to do that is because you would drop the ohm load too low by hooking up both voice coils.
what kind of sub do you have, and what is their voice coil config?
what kind of amp, and what are its stats?
wats the sub and wats the amp???
2 kicker copms vr 2 ohm, power acoutik 1000bd. i think the amp 800x1 rms give or a take. stock alt the sub might be getting 325wrm it just not that loud and it is in a ported box tune at 35.
Power Acoustik 1000bd? Sure you dont mean Rockford Fosgate 1000bd?
Power acoustik just released the A1000DB which is the amp he is talking about.
And no you cannot just hook up one voice coil as it will more than likely damage the sub and also will void the warranty.
wire it like so and you will be set.
i just ran only one vc on eack sub it like 3x as loud //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif just a short-term fix until i get a bigger amp.
alright, well that is your choice. But i strongly reccomend against it. And there is no way it should be louder unless you had something hooked up wrong before.
idk but it crazy loud. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If you do that you are cutting the subs power handling in half, so you are now overpowering that single VC and will eventually blow it
Wire it correctly... At 2 ohms that amp will do somewhere in the 500w range, giving each sub 250w, which is a good number for those cvr's (300rms right?)
05 kicker comps vr r 500rms each 250or 300 wrm is not enough power to run both of them.
dron178
dron178
OKC,Ok
monte_carlo97
