Visonik
yep thnx deja...
i was thinking soundstream sst4.6 for the front n sst6.5 for the back
I wouldn't run SS speakers.... just some friendly advice.
Check out the Alpine and Pioneer REV coaxs:
4x6
6x9
If you're going to amp them, a clean 4x50-75w rms would do them (and you) nicely.
Another option if you can:
Make a 4x6 -> 6" baffle out of MDF and use the RSd6cs components. Amp them with a clean 2x120-150w rms and forget the rear speakers since you'll have subs. Take out the 6x9's and let the subs vent into the cabin through the speaker openings.
4x6
6x9
sorry im new to car audio...what do u mean baffle?
4x6
6x9
x3!!!!!!
Revs are a good choice, so are the RSds if u make a baffle
An adapter.
Take out a stock 4x6.
Set it upside-down (cone down) on a piece of MDF.
Trace around the speaker and mark the mounting holes.
Remove the 4x9 and place the 6" speaker inside the 4x6 tracing.
Trace the 6" speaker and mark the mounting holes.
Cut the outside of the 4x6 tracing away and drill out the mounting holes.
---note: you may have to enlarge the dimensions before you cut so that there is enough MDF for the 6" speaker to mount and be supported.
Cut the inside of the 6" tracing away and drill out the mounting holes.
There ya go!
GbJordanC911
~tEh PwNzOr~
GbJordanC911
Green Bay, WI
GbJordanC911
