Visonik V4000XD cutting out????
travis420
i just got this amp new Visonik V4000XD once i turn it up to 1/4 gain it cuts outs for a sec. it dost get hot i have 3 batts but it stills cuts out it has unregulated power supply i want to get the full power of this amp i need 17V DC to reach that how would i go about i have two solo x 12s playing 2 ohm what do you think???
Checked out your cardomain site. How big is that box for those solo X's. Might look into that your box being way to small for subs.
Other than that. Check your grounds. Visonik amps dont like cheaply grounds.
i have a new box now and its huge i had 2 take me seats out in order for it 2 get into the car so the box is big enough and if the box was 2 small it wouldent make the amp cut out
I don't think its anything to do with your subs/box unless theres a lose wire.I would bet its your voltage.Check the voltage on the remote wire while listening to some music and see if its consistant with your power voltage.I had a similar problem, installed a relay and it was gone.
O no I wasent saying that your box being to small was going to do anything to your amp.
Was saying two different things. Said one thing about your box. Good to hear you have them in a bigger box. And the other thing I said about your amp. Checking grounds.
travis420
travis420
Ohio
audioatg
Mike Mccabe
