Visonik V4000XD @ .5ohm = amp HOG!!
the mod just cuts the protect so you can run it at 1 ohm, doesnt make it 1 ohm STABLE, dropping voltage like that its gonna smoke, people do it for comps, they are current hogs to begin with, good luck
Ya I was always curious what the "mod" exactly did, I know it let it run @ lower imp is all, when I got it repaired the first time i blew the mosfets I asked vince to take a look and to see exactly what was modded, he said only a few resisitors were removed.
Hell, I might go back to 2 ohm tonight after making a video or 2, I made it quick interchangeable with posts for every voice coil + and - with nuts and bolts out the back, would only take a few min to switch around
I run my orion xtr 2400 pro @ 1 ohm daily and its only 2 ohm stable on stock electrical and its holding up just fine. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
because the amps is 2ohm stable and you are running it at .5
I seen another guy run it @ .5 for burps....
I also just came across 2 Kinetik 2400's for $500 brand new local, probly gonna scoop them tomorrow if I have enough after groceries and gas, to good of a deal to pass
And with rise I figure Im up there above 1ohm atleast anyways......
Dmm doesnt even read .5 sitting
HMMMMMMMMM, more batteries and stock alt, or big alt, and keep the 2 batts I have....
WOT
Banned
WOT
Toronto,CANADA
WOT
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
