Viper 791xv
30 amp relay k...both 12+ fused with 30 amp fuses?
sorry just wanna make this work
the last wire I forgot to ask was the status output if i need it
okay so the relay looks like this?
k thanks for all the help.....I might get it installed on saturday...thanks again...I will get the 30 amp relay tomorrow thanks for the help!!!!
how much is a relay?
o yah one last question.....How do I hook up the horn to the system
it has a horn input on the alarm just needs a relay how do you hook that up?
what amperage relay?
o yah one last question.....How do I hook up the horn to the systemit has a horn input on the alarm just needs a relay how do you hook that up?
Brown wire off the main brain harness to the red wire from the siren... then ground out the black wire off the siren.
You want to hook up your horn with the siren?
you're going to need a relay...
85-brown wire from brain
86-ground
87-12v or ground whatever your factory horn needs
30-output to your horn wire
no...there is a wire for the car horn on this alarm which is negative 200mA output
to the car horn
Nismofreak
VIP *****es
Nismofreak
ATL
Nismofreak
NorthFramingham
    Jun 30, 2026
