Viper 791xv
Nismofreak
VIP *****es
Well I got my alarm finally and need some help on 2 wires
activation wire? do I need it or not and where do i connect
the door locks
the instructions ****. I got green and blue. green=(-) lock (+) unlock. Blue= (+) unlock (-) lock. My locks are negative how do I hook it up?
help will be appreciated!!!
Sorry I ducked off a couple nights ago, stopped by my buddy's to help him with a remote start.
Green will be your neg lock and blue will be your neg unlock. Just hook them directly to your lock wires... no lock motor, but lock wires.
Activation input is also not needed.
Also be sure to ground out your neutral safety wire or put a switch on it.
x2
well no for more questions shyne.
I got 2 starter in my car and how should I connect it
its connected to one wire
how should I hook up my ignition wire from the satelite relay?
t tap it?
the alarm has a second starter ouput on the 4 pin harness that plugs into the relay satellite use it to trigger a relay for second starter output.
as for your ignition t-taps = //content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif
solder is preferable but if not available strip back the shielding poke a hole in the wire, then thread the wire from the remote start through the hole and wrap it around the bare wire. Secure with tape and a wire tie .
that is what I meant
I solder all my connection lol haha
you mean the (-) a stater output on a small harness?
and should I connect it to the starter side or key side
of course I will use a relay lol
This is how I do every connection at work... only wires I solder are factory wires that get cut and bypass wires.
As for second starter you are going to need to wire in a relay...
85-12v
86-purple wire off of mini-4pin harness
30-12v
87-starter wire
Like I said post them up as you come up with them and I'll respond here. I'm thinking about doing a tutorial maybe for remote starts/alarms... do enough of them at work.
85-12v
30-12v
87-starter wire
//content.invisioncic.com/y282845/emoticons/word.gif.64b12e39f936af3b4fff38a1c0bd0244.gif as do i
o okay
is this the right way to connect it to the relay? since I need it and connect it to the starter wire
Nismofreak
VIP *****es
Nismofreak
ATL
Nismofreak
Mike Mccabe
