Video Splitter
silentdub
usa
I have two lcd panels in the back, then I use a video splitter and connect one source to both units, I get some interference and lines on both monitors.
If I only plug one it, then it is picture perfect.
I have tried both a DVD player and PS/2. It seems as though I need to split the signal better to isolate each monitor.
I have using a simple Y adapter for the video.
Any ideas what I can use?
What connection are you using? You might be able to also loop out of one of the LCD's if it has the option. A vga amplifier should be able to give you a clean signal up to 100ft, 5-wire should be able to run much further with an amplifier. If you're already using a 5-wire or vga amp you'll need a humbucker to get rid of the interference that's causing the lines to appear.
silentdub
silentdub
usa
silentdub
