vibe 250 protection again
or set the gains properly, use a large enough power wire, .......sounds like the gains are eitehr set to high....or the main power wire isnt large enough for the amp...its trying to draw more power than the wire will allow.....
im using 4 ga. and i know its not the gain ...
its all the way down ... im just using bass boost ...
or i would set it 1/3 and bass boost off ...
still same problem ...
stupid amp ...
amp is pissing me off ...
i should have gotten the opti ...
or better yet .... go crossfire ...
sent message ...
AMPLIFIER GOES INTO PROTECTION WHEN I HIT LOW FREQ. AT HIGH VOLUMES ... HOW WOULD I ELIMINATE THIS PROBLEM...THANKS ....
???WOULD A CROSSOVER HELP???
reply...
support@lanzar.com | This is spam | Add to Address Book
To: "CHRISTOPHER OCAMPO"
Subject: Re: VIBE 250
Date: Mon, 19 May 2003 11:16:07 -0400
Sounds like the amp is lacking power, look into the amperage of the fuse prior to your battery it should be aprox. 10 amps higher than the amperage fuses loaded in your amplifier to begin with.
my translation ... my fuses on the amp are 25+25=50 ... should my fuse on the wire be 60 then? if so ... im using 4 qa. to distrubitor block to 8 ga. fuse is i believe 80. please help
...subs are crossfire p1 12's dvc (4 ohms per coil)
...amp lanzar vibe 250 2x250@4 ohms 2 x450@2 ohms 1x900@4 ohms bridge (bs specs)
either way i wire them up 2 channel or bridge it still would go into protection ...
when it hits low freq. at high volumes ...
i read on another forum (dbdragracing.com) that the vibe series's protection circuit are very sensitive ... that really sucks ... but im hoping for a solution ... cause i know these subs can really hit ... i ran them off one off my boys rf 2000 amp at 700 watt total to both woofer and it was two to three times louder ... please help me ... thanks
so u have them wired like either of the following and it happens correct?
thats a 2ohm sterio load which is to low for the amp
and thats a 1ohm mono load which is to low......
so if wired like either of the above mentioned ways your presenting to low of an ohm load for your amp....
what's probably hapenning is this. the amp is probably barely keeping up with the low load. It's straining to stay active. when these long low notes come, teh impedance across the coils does drop somewhat significantly. this is why it cuts out. these impedance drops are too low for the amp to stay stable.
thechris
thechris
lakewood, ca
thechris
