Very Urgent - Please Help :: Pioneer TS-WX610A sub coils => each 2 ohm OR 4 ohm?
alpb
Hi everybody,
This is my first message and I need your urgent help.
I have a blown Pioneer TS-WX610A active spare sub and it's in repair shop now for coil replacement.
There is no info on internet about the specs of the two dual coil subwoofers included in this device.
The repair shop insists that each coil of each sub should be 2 ohms.
But when I look at the internal wiring, each coil (2 coils x 2 subs = 4 coils) is connected to the outputs of the PAL007C chip which has 4 outputs as 4 x 45 W / 4 ohms.
So,
What should be the impedance of each coil? 2 ohm or 4 ohm?
The only data on TS-WX610A I've found is:
Speaker specifications
Size..................................................... ø 100(3-7/8" Dia.) mm × 2
High compliance, rolled edge
Heat-resistant voice coil
Strontium magnet: 280 g (10 oz)
Amplifier
Max. Power output.......................100 W × 2 (80 Hz, 30 % THD)
DIN output power (DIN45324, 80 Hz, 2.0 ohm +B=14.4 V)... 70 W × 2
INPUT LEVEL (at Gain Max)
(RCA).......................... 60 mV+60 mV/20 k
(Speaker line)......................1.2 V+1.2 V/5 k
Power source.................. DC 14.4V (10.8 V to 15.6 V allowable)
Max. current consumption.....................................................14 A
Grounding...........................................................Negative ground
Your help is very appriciated. Thanks!
Full specifications
Main Features
Amplified Subwoofer
Space Saving
Impedance 2 Ω
Frequency response 25 - 180 Hz
Sensitivity 101 dB
Woofer material PP cone woofer
Built-in amplifier Yes
Built-in variable LPF (50-125 Hz, -12dB/oct.) Yes
Dimensions 388 x 144,3 mm
Magnets Ferrite
Weight 4.9 kg kg
Woofer Size 2 x 10 cm
alpb
alpb
Turkey
alpb
    Jun 24, 2026
    Jun 24, 2026
