very simple question
cotjones
ok i can't make the question any more simple than this... will this diagramed setup produce cancellation and if so why?... if your not fully answering the question don't post better yet don't even look at the thread...
Are they both going in the same space (i.e. trunk or hatch as opposed to the 10" being used in doors or kicks and the 15" in the trunk or hatch? If so why would you want to do this? If they are not going to be mounted on the same plane than cancellation should be kept at a minimum but if they are on the same plane they most likely will be some cancellation issues.
yes why will it cause cancellation?
1 is larger and in terms will get louder and when playing the same freq. the other will be canceled. waste of money. just get some nice mids to play the frequencies the sub's are missing
i don't have enough room for strong mids but i still don't see how they would cancel when they don't play the same frequency (with the exeption of maby at 45 htz exactly
it can be done just take's a little more to do it. if that is what you want then go for it. make sure your crossover points are set correctly. why cant you fit some better mids? what car do you have?
if done right you can make it work. people here dont relize that. people have been doing 10/15"s way back in the day,
i have noticed you in my other posts i have the setup and i think it sounds better than alot i have heard, no one that has ever heard it has told me anything is wrong with it i took it to nopi and an the autorama show in houston
cotjones
cotjones
Wilmington, NC
squeak9798
