V-shaped box design, check please
rbenz27
This is a rough sketch of what I can fit in my SUV. The 2 drawings on top are internal dimensions and the last one on the bottom is the whole enclosure made with 3/4 MDF.
I'm aiming for a 0.75 cu. ft. enclosure. I'm not sure if I calculated it correctly.
Is it accurate?
no.
to find the area of a trapiziod prysim its 1/2(bhd) so it would be 0.1041 instead of .130. i would personaly make the box a rectangle for strength reasons and then add the sides on as hollow pieces
no.
Thanks. I just looked at my original draft on paper and the depth of prism should be 3.75 instead of 3.
It should come out to 1.302 and 0.7552 total right?
Yes, a rectangle would be stronger but there is just no way a 0.75 rectangle enclosure would fit in the wheel well of the car. Hence, the v-shape design.
rbenz27
rbenz27
Honolulu, HI
rbenz27
