Using kinetiks for starters?
Weeznur32
Hey guys i havent heard of many people using kinetiks to start their cars i was just wondering if they will be reliable for doing so.
Also right now i have a wet cell batt with like 800 cold crank amps....is it safe for me to keep this and add a kinetik in the back b/c i heard wet cell and dry cell dont mix.....thanks.
I've been hearing mixed things about what i should do.
i have around 2700 watts, 2000 to subs and 700 total on frontstage.
right now, i have 1 gay autozone type batt under hood and 1 walmart batt in back that pretty small.
what should i do about my battery situation?
some people say i should drop 1 batt under the hood that is biggest that will fit in my car using a kinetik / optima yellow top under the hood and call it a day others say, replace the starting batt with like an everstart, duralast or decent name brand battery u find at walmart / autozone and the works, and add a kinetik 2400 in the back?
what should i do?
also the way i have my wiring now is fused pos. run between the batteries, and battery under hood has it ground to chassis when i did the big three, and the battery in back has a ground from the battery to the frame / unibody of my car in the back of my trunk. i think kinetik wants me to run another whole neg run between the batteries?
Which one do i do?
Mike-
K so it sounds liek they work good for starting my car but i would like to save money and just put like a 2400 in the back....CAn i mix a kintetik with a wet cell battery for the starter?
Well there is a reason isolators were made. Two different batts will fight each other to death shortening their life drastically. Get a yellowtop or something like it under the hood with a high output alternator.If you dont have enough juice being produced another batt is not the answer.
Weeznur32
Weeznur32
Seattle
csnut18
Mike Mccabe
