Using fused distro block for ground?
jinx8402
RI
I have a question, that I think I know the answer to but want to make sure before I purchase from Knu. Is it ok to use a "bar" to connect 2 points of a fused distro block on my ground wire? The reason I am asking this is 2 fold...
1. I only need 2 ground wires, so getting the 3 output ground box is not needed especially since it costs more than the dual fused block (I'm looking at the KonFUSED line).
2. Also, I want to have a sleek and symmetrical look.
Also, what type of metal would you suggest using? I think I remember seeing someone else do this actually, but would like someone who has a better understanding of this to give their opinion.
Thanks
First thing that comes to my mind is why did you bother with the extra expense of a fused distro for cabling that carries no positive current?
(Grounds need no fusing //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif)
Well, from Knu, the dual output fused block is less expensive than the 3 output ground block. So it's not more expensive. Check it out. As you can see the ground KonFUSED block is more expensive than the 2 Way KonFUSED power block
Second, I know you don't fuse the ground, that is why I'm asking if I use a solid brass bar as a jumper between the 2 points. And finally, I think it would look more symmetrical having the same size/shape block for both ground and power.
jinx8402
jinx8402
RI
helotaxi
vegang
vegang
