michaelking
Okay, I'm about to purchase a enclosure with two 12 inch kickers that are rated at 400 watts a piece (And have been wired down to 2 ohms with one 2 ohm speaker output) and an MTX amp which is rated at 800x1 @ 2 ohms. I also have 4 gauge wire fused at 100 amps running from battery to an unfused dist block. Here is a link to the sub and amp:
(Amp)
http://www.crutchfield.com/p_236TC8001/MTX-TC8001.html?tp=115
(Sub)
http://www.crutchfield.com/p_2067DCVR12/Kicker-07DCVR122.html?search=CVR122
What I'm having trouble figuring out is, the gauge of wire to run to each amp. Crutchfield says I can run 4 gauge to the mtx and 8 gauge to my Profile AP1040 AMP. Today I was told that I Could use my existing dist block to run one 8 gauge wire to the AP1040 and a 4 gauge wire to my MTX. Confused because I always thought that when running 4 gauge wire to a dist block, you must branch it off into 8 gauge wire.
The profile AP1040 has two 30 amp fuses and the mtx has three 30 amp fuses, so what do I need to do at the inline fuse, which already has an 100 amp fuse attached, should I keep that or do I need to upgrade to a larger fuse?
One last question, if you look at the mtx amp you will see that it has a speaker one and speaker two input, how would I go about connecting my 2 ohm kicker sub to the amp (The sub only has one speaker terminal at 2 ohms?)
Any help would be appreciated,
Mike
(Amp)
(Sub)
Mike
