Using Crossover to change impedence
No.
You could use a resistor in parallel with the sub to present a different impedance to the amplifier (4ohm resistor in parallel with the 4ohm voice coil for a final 2ohm load)....but that's a worthless fix, since even though the amplifier would be outputting it's 2ohm power, half of that power would be wasted as heat by the resistor...leaving the subwoofer to only receive the same amount of power as it would have been if wired directly to the amplifier at 4ohms.
There was an older product produced by Veritas and Stinger called the Accumatch....but they are pretty hard to find, and even then there are mixed reviews about them. I guess they went pop pretty easily, and most people were very unhappy with the performance of their speakers when having the Accumatch connected.
So, overall....you're just screwed //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Which is why having DVC subwoofers comes in handy.....
I think its possible to do that, but any extra power that is put out by the amp will just go into the crossover and be burned up as heat.
It would be the same thing as wiring a 4 ohm resistor in parallel with the speaker, sure the amp will be putting out more power, but it wont be going into the speaker.
Edumacate me my brothers //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Isn't doing this pointless as squeak said. Meaning the sub will see the same power regardless. Any extra power will be turned into heat in the resistors. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
mr_ruready
mr_ruready
Moore County, NC
ramos
