Using a car amplifier at home ?
Uhh...your amp is for car audio, which is 12V. Home audio amplifiers are made for a 120Vac outlet.
There are power supplies you can buy though that you plug into the wall, and can be set to 12 or 14 V or whatever, but I'm not sure if you'd want to be playing daily off that. I'd only use them to test an amp personally.
Why not sell your amp and buy a decent ht amp?
A power supply needed to run anything over like 100w is gonna cost some dough. For the price of it, it isnt worth the money
Sure it is.. if it works & such, it's a life long keep. Worth spending tha money, IMO.
IIRC, most high wattage home amplifiers = lots o' money. I'd rather spend a little bit of dough on a power supply, one time.. vs. maybe a couple of HT amplifiers..
That's just me.
radioshack has some power inverters that convert 120v AC to 12/14v DC....
the price you pay for should be more along of the lines of how much amperage the inverter has... and you obviously need enough amps to power the amp with the amps efficiency and power draw in mind...
The power supply will be more than a home audio amp with considerably more power than an amp the power supply could support. A basic home amp is cheap and gives you preamp functions like volume control and input selection and a tuner. You can get a basic home receiver for $100. A 10A power supply will cost about 50% more.
Wow lots of replies and opinions on this one...
If I dont find a buyer for the amp I might give it a shot to test the bugger
ani
ani
neonrt
