mmouse57
I know most of the time we use electronic crossovers to cut mids at say 100hz and so on and use the passive xovers that come with the component kits to do the rest.
but looking into peiceing my own tweeters with midranges and midbass then subwoofers all from diff manuf. I find a big diff in spl so running say 3-4 amps with a full 18-24db electric xover seems a way to fine tune each to get perfect sound/output level to match the other diff brands speaker with the other speakers in the system.
http://www.sonicelectronix.com/item_6323_Clif+Designs+CDQ3X.html#
so if i was to use say this cxover for high/mrange/midbass and run 3 50x2 amps and 1x400w amp for subs running the crossover here set at say 2k-up for tweeters, 400-4k for midranges, 70-200hz for midbass to the three amps would this work right?
Im basicvaly asking what electronic crossover would i want to take the place of a crossover system that comes with say the focal utopias
http://www.crutchfield.com/p_091NO7/Focal-Utopia-Be-No-7.html?tp=106&avf=N
as in i can cut the highs, midrangae, midbass and so on all at 18-24db slopes so i can run each set of speakers on its own amp at there own set freq from set hz to set hz
there are alot of audiocontrol xovers but im not sure what unit is what i would want or if a diff brand is best.
dont want to spend more than $300 btw
hope this makes sense
thanks guys
Jason
thanks guys
Jason
