US Amps??
here you go Power Handling (MAX) : 1000 Watts
Power Handling (RMS 1-Ohm) : 590 Watts x 1
Power Handling (RMS 2-Ohms) : 380 Watts x 1
Power Handling (RMS 4-Ohms) : 200 Watts x 1
Signal to Noise Ratio : 95dB
Frequency Response : 20Hz - 500KHz
Low Level Input Sensitivity : 200mV - 6V
Continuously Variable Low-pass Crossover
Base EQ Control (45Hz) : 0 - 12dB
Line Output with Low-pass Crossover
Platinum-plated Connectors
I just received the amp actually.
I have not installed it yet. I know i should have asked first but not a bad price. I found the msrp to be like 380 or so.
i just wanna know if anybody has used this amp or have even used any of teh new us amps.
I know the old ones are badass, not sure about teh new ones thats why i ask
i really would have saved my money and bought a md2 or md3 .....those are the budget/cheap made us amps.....they are no where near as good as the old school us amps they made back in the day.......i think the xt line is made in china....//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif...they are not ces rated ....
good luck getting 500 watts out of it....the xt4000d only puts out around 900 watts kicking and screaming....
XT is US Amps' crappy line, especially for the price. Newer US Amps, you don't really get what you pay for. Unlike the good old days. Those amps were beasts.
But to the OP, I think it's best if you sold that amp and go find something else that'll be better for the price.
i actually have this amp and i am running 2 10"s off it. its my first system though so i dont have anything to compare it too. It seems to run pretty good i have never had any problems with it. some days it seems to play a little louder than others but i dont know if that is the subs or the amp.
Really not a bad amp... The whole line isn't bad. I've installed several of them and they're fairly nice... XT2000d will get around 900W RMS and the XT4000d around 1200W RMS... No they're not rated, however they put out some nice power. My partner installed a xt4000d in an Infiniti QX4 with 2 TC-1000 and it was hell... Really not bad amps for the price however they are budget amps...
thanks guys, but do you think it will be better than my lanzar opti drive. im only getting about 100 watts per channel. so i should get more power out of my us amp...
laxplayer92
laxplayer92
maryland
laxplayer92
