AcidikBass20
Bass Addict
Which and Why? DAILY USE but I want to the most power I can get and most RELIABLE.
Dont worry about budget. I'm willing to pay.budget? try a dd z1a mines worked well
Totally not true. First none of these amps will do .25ohms daily. The NEW 7k2d amp is designed to be run at 1ohms all day long. And if you wanted to run it at 2ohms it'll still do more power than most amps out there. lolUS Amps AX 3200DEHifonics XXV Goliath Good amps to use for daily driving..
Stetsom 7k2d
Better amp to use for SPL only. Or keep the ohm load up for daily and be okay. Meaning Higher ohm load not at .25 Like over 2ohms. I get this from what I have read over the forum boards here and dbdrag.
If you read it again. I didnt say anything about the other two amps running at .25 daily. Nor did I say the stetsom amp to run at .25 amps daily. So I dont know who said all of those amps would run at .25 I know I didnt if you read it correctly.Totally not true. First none of these amps will do .25ohms daily. The NEW 7k2d amp is designed to be run at 1ohms all day long. And if you wanted to run it at 2ohms it'll still do more power than most amps out there. lol
