US AMPS 300X ULTRA HIGH CURRENT 2000 watts peak
shaggyballs
16
detriot
Very clean A/B CLASS
2x300 watts RMS - 4 ohms
2x450 watts RMS - 2 ohms
1x900 watts RMS - 4 ohms
2000 watts total power output
POWER SUPPLY OVERAGE RATIO
6.6-1
(Means a bunch of hidden power)
300x old school cheater amp
This is a old school beast
AKA ....cheater amp !
Hand crafted in Florida U.S.A.
Gently used for 1.5 years only ran 1 set of 6.5 Boston pro separates at 4 ohms
With the gain all the way down
It is equipped with smart amp technology (shows if amp was over heated ect.)
Just hook it up and see a complete history of the amp.
This amp has never seen a sub in it's lifetime
The stick on emblem is still new ...not peeled or stuck
$ 350 obo
$19.99
Image hosting, free photo sharing & video sharing at Photobucket
I talked with the rep at us amps a few years ago he said it would , but might get hot if you push it.....it was designed to run clean power at 4 ohms bridged
It will hit 1800-2000 clean watts peak bridged @ 4 ohms
It is a class A/B amp after all.......I would bet it will do more if you don,t mind a little distortion......But I like it clean!!!!!
im sooo sorry i got got this mixed with the guy selling the other us amps. i got a text this morning about the other us amps being sold changing pix and using other people pix and i got confused VERYY sorry, totally my bad.
i was tring to warn others bout shady guy but mixed up ;(
I was very concerned when i heard this so i removed the glass and there was some dust.....I carefully cleaned it and posted close up pics taken under a 1000 watt halogen please look again!
video taken 5/29/2012 to show amp working and both channels functioning properly
click here for video of amp powered up
358
512
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
shaggyballs
shaggyballs
detriot
shaggyballs
    May 31, 2024
    May 24, 2024
